Why do I get the following relsult in my FIR filter output
- 3 years agoYou are using logical right shift for signed variables which corrupts the sign bit. Try arithmetic shift.
Thank you! excellent answer. After doing some minor changes to my design (especially those which you've mentioned), my ideal simulation in modelsim worked great. However, after synthesizing my project using design vision, I could not get appropriate results (I mean in non-ideal simulation using the files which were produced by design vision). it gives a lot of &hold and &setup time error and output is completely don't care. I have checked the schematic view in synthesizer. It seems flawless. just in the log file, synthesizer said:
Warning: Verilog writer has added 4 nets to module FIR filter using SYNOPSYS_UNCONNECTED_ as prefix. Please use the change_names command to make the correct changes before invoking the Verilog writer. (VO-11)
Can you help me?
Thank you
- mohamis3 years ago
UPDATE
When I click on check design in synopsis, the following warnnings come up:
Warning: In design 'FIR_Filter_DW01_add_0', port 'CI' is not connected to any nets. (LINT-28)
Warning: In design 'FIR_Filter_DW01_add_0', port 'CO' is not connected to any nets. (LINT-28)
Warning: In design 'FIR_Filter_DW01_add_1', port 'CI' is not connected to any nets. (LINT-28)
Warning: In design 'FIR_Filter_DW01_add_1', port 'CO' is not connected to any nets. (LINT-28)
Warning: In design 'FIR_Filter_DW01_add_2', port 'CI' is not connected to any nets. (LINT-28)
Warning: In design 'FIR_Filter_DW01_add_2', port 'CO' is not connected to any nets. (LINT-28)
Warning: In design 'FIR_Filter', the same net is connected to more than one pin on submodule 'add_2_root_add_0_root_add_59_6'. (LINT-33)
Net 'add_6_root_add_59_6/carry[6]' is connected to pins 'A[7]', 'A[6]''.Do these warnings cause error in modelsim?
