14 years agoWhich clock pin can feed transceiver without DQ pins limitation cycIVGX ?
I am developing a custom board with 2 ddr2 x16 and a sata II (3,125Gbps) interface on a cyclone IV GX / F27 package. I did this pinout: - DDR2_a => bank8 / DQ3T x16 - DDR2_b => bank3 / DQ3B x16 - SATA RX/TX => GXB_RX4 / GXB_TX4 - Clk_125MHz_p/n => Ref_clk_3_n/p => use pll_8 as a MPLL and pll_2 as a GPLL - Clk_50Mhz => bank4 => use pll_1 as GPLL I use the same SATA configuration in my cyclone IV GX eval kit and it works (with a critical warning: input clock inclk[0] may have reduced jitter performance while used for transceiver channels that configured at a data rate that is higher or equal to 2.97 gbps because it is fed by a clock pin "pin_l15".). But I am afraid that ddr2 won't work on my custom board. There is no compilation failure with this pinout for my custom board but I have just found in the cyclone IV pin connection guidelines that there is some restrictions for transceiver working at > 2.97 Gbps. It says that if refclk2/refclk3 is used for feeding transceiver, you can not use bottom/top banks for x16 DDR (page11, http://www.altera.com/literature/dp/cyclone-iv/pcg-01008.pdf). If I use closer input pins (ref_clk_4 or ref_clk_5) compilation fails… So the problem is if I use ref_clk_3 ddr2 probably won't work and other clock pins don't work. My need is to find a pinout to have: - 3,125Gbps interface and its 125MHz dedicated clock input pin - 2 ddr2 interface which fill only one bank per interface (I need most of other IOs for my design and they have different voltages). Is it achievable? Thanks in advance !No RepliesBe the first to reply
