SYiwe
6 years agoWhat's the proper DDR4 termination method in Intel FPGA?
My design contains a DDR4(discrete component) EMIF, and I terminate the address/command/clk in the same way with Arria10 development kit DDR4 daughter card(DIMM). Here're my questions: The address...
NurAida_A_Intel
6 years agoHi SYiwe,
Thank you for the diagram and sorry for the confusion. My bad, I was not referring to FPGA output clock at first.
Yes, the CK0_T/CK0_C should be terminate pull-up to VTT. You need to follow the terminationguidline based on the I/O standard you used.
Aida
