13 years agowhat's non-inverted input pin ?
During complete my project, I stuck at a problem with pll. I use kit Cyclone III devlopment kit I try to use clock 50MHz to feed pll1 by pin AH15. During synthesing and analyzing it returns error: Error (15065): Clock input port inclk[0] of PLL "adc_pre:inst1|CLOCK_GEN:clkinst|altpll:altpll_component|CLOCK_GEN_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block Info (15024): Input port INCLK[0] of node "adc_pre:inst1|CLOCK_GEN:clkinst|altpll:altpll_component|CLOCK_GEN_altpll:auto_generated|pll1" is not connected Also, I found a solution here. but it doesn't help me. I try to write the code to the .qsf file in folder of quartus project. But it doesn't help. http://www.altera.com/support/kdb/solutions/rd02012010_744.html What does the " non-inverted input pin" mean? and How can I resolve this problem? Please help me, thanks11 Replies
It means that the PLL needs to be driven from a pin with a CLKIN or DIFFCLKIN_P function, but not a DIFFCLKIN_N (inverted input) function (unless your clock is a differential input, in which case, both DIFFCLKIN_P and N would be used).
Cheers, Dave
