11 years agoWhat is the Slew Rate VALUE of Cyclone IV?
Hi there, As the handbook tells, we can set three kinds of Slew Rate in "IO Assigment Editor" , 0,1,2, in which "0" means slowest and "2" means fastest. Is anybody knows what is the specific...
11 years agoJust to add that you should take note of the dv/dt info in the IBIS model is obtained using the load of 50Ohm resistor to ground.
