11 years agoWhat is the Slew Rate VALUE of Cyclone IV?
Hi there, As the handbook tells, we can set three kinds of Slew Rate in "IO Assigment Editor" , 0,1,2, in which "0" means slowest and "2" means fastest. Is anybody knows what is the specific...
11 years agohie xiaoyi594,
i think your original question was on the value of this slew rate. E.g. dv/dt in V/ns. bfkstimchan gave a very helpful comment, referring to the IBIS model. let me add on how i get this info. you can get a good idea of this "value" by referring to the RAMP (dv/dt) section of the I/O standard. i attached a screenshot example of how you would check this in your IBIS file. https://www.alteraforum.com/forum/attachment.php?attachmentid=10666 of cos just download the IBIS model from the link below for your device: https://www.altera.com/support/support-resources/download/board-layout-test/ibis/ibs-ibis_index.html good luck!
