11 years agoWhat is the Slew Rate VALUE of Cyclone IV?
Hi there, As the handbook tells, we can set three kinds of Slew Rate in "IO Assigment Editor" , 0,1,2, in which "0" means slowest and "2" means fastest. Is anybody knows what is the specific...
11 years agoThis is largely dependent on the load the pin is driving. Some manufacturers will specify a slew rate for a particular load (e.g. 15pF). Altera chose not to.
If you're designing something that is slew rate dependent then I'd suggest you don't rely on an FPGA to control that for you. Cheers, Alex
