10 years ago
What is the register's initial value after FPGA power up?
hi:
For example, after CycloneIV device power up, what is the initial value of the internal registers?
I found a interesting thing: usually,we set the initial value for the registers like this: always@(posedge clk or negedge reset) reg <= 0; But when you trace the reset signal to the most original, it would be pure controlled by the FPGA hadrware itself instead of verilog statement.
    Registers will usually power up to '0' unless otherwise specified with an initial value or async reset
    Thanks for your reply. Dose this mean the verilog statement like : always(posedge clk or negedge reset) rega <= 1 will force the FPGA to load the rega to logic 1 as soon as power up, even the external reset hardware dose not active?
    what that case, it is unlikely to create a register for rega as it is always driven to 1.
    but in the following case it should:
    always @(posedge clk or negedge reset) begin
      if(reset == 1'b0 ) rega <= 1'b1;
      else rega <= ip;
    end
    sorry for my provious reply. let me update as below:
    If I use always@(posedge clk or negedge reset)
    begin
    if(!reset) rega <= 1;
    else
    rega <= in_a;
    end
    Dose this mean the FPGA will force the FPGA to load logic 1 to rega as soon as power up, even the external reset hardware dose not active?
    Is this done by the synthesis tool or need to config something else?
    --- Quote Start ---
    --- Quote End ---
    This should be done by the synthesis tool and there should be a message about power up values for specific registers where a default is assigned or infered from async reset.
    Roger that! Also I have seen the statement like: reg[15:0] cnt = 16'd0; in the source code. Does this has the same effect to load 16'd0 to cnt as soon as FPGA power up? The complete code is shown as below:
    module reset(
    input clk,
    output rst_n
    reg rst_n_reg;
    assign rst_n = rst_n_reg;
    always@(posedge clk)
    if(cnt != 16'hffff)
    cnt <= cnt + 16'd1;
    else
    cnt <= cnt;
    rst_n_reg <= (cnt == 16'hffff);
    endmodule
    These is no async reset in the code and this module is dedicated to generate system reset to other modules. As this purpose, the cnt must be 0 aftera power up to generate the rst_n.
    Is my understanding correct?
    --- Quote Start ---
    --- Quote End ---
    You can have both:
    1. Initial values that provide the default register state after FPGA configuration
    logic [31:0] myreg = 32'h12345678;
    signal myreg : std_logic_vector(31 downto 0) := X"12345678";
    2. Reset values, eg., synchronous reset
    if (rst)
    myreg <= 32'hABCDABCD;
    process(clk)
    if rising_edge(clk) then
    if (rst = '1') then
    myreg <= X"ABCDABCD"
    I've just been running some tests with Xilinx (ISE) and Synplify. For Xilinx devices, the initial value is the INIT value for their registers, while the reset process generates the SRVAL.
    Synthesis tools can choose to do what they like if you do not fully specify the power-on state, eg., Synplify will use the reset value as the init value, so your FPGA will power on with the reset value, even if reset did not assert ... in general this is probably what you wanted.
    Because I like Modelsim and synthesis to match, I typically assign both the initial value and reset value to the same value.
    Cheers
    Dave
