14 years agowhat is the different between * and IP core multiplier
hi ,everyone ,i have a question about the mulitplier. i am a newer in FPGA ,now , i wonder the different between the mulitplier constusted by * in HDL and the one generated by Ip core ,what is...
14 years agoBy any chance is the module you are testing this with at the top level? If so I suspect your input and output registers are being packed into the I/O. Either assign those inputs and outputs to virtual pins using the assignment editor or just shove a bunch of pipeline stages in front and after the multiplication in your HDL file. This will make sure you'll iscolate the multiplier from the I/O. So in other words do this:
Register --> register --> register --> register --> multiply --> register --> register --> register --> register If this causes your timing problems to go away then don't worry, you won't need that kind of pipelining once you feed the multiplication with on-chip inputs and outputs (and if you do that means the surrounding logic could use some pipelining).
