14 years agowhat is the different between * and IP core multiplier
hi ,everyone ,i have a question about the mulitplier. i am a newer in FPGA ,now , i wonder the different between the mulitplier constusted by * in HDL and the one generated by Ip core ,what is...
14 years ago --- Quote Start --- Try writing it the same way as shown in the multiplier template under the Edit menu. You can find it here under the templates: Verilog HDL --> Full Designs --> Arithmetic --> Multipliers --> Signed Multiply with Input and Output Registers. --- Quote End --- I just tried that, and it gave me the same result as my own hand-written Verilog. So, the current fmax summary: lpm_mult with two cycle latency = 180 MHz Verilog * operation with input and output registers = 90 MHz Quartus II Verilog signed multiply with I/O registers template = 90 MHz My .sdc file is setup to try for 200 MHz in every case.
