Finees
3 years agoWhat is the correct version of Quartus to use the Cyclone 10 GX delevopment kit?
Hi all
I have a Cyclone 10 GX development kit and I am testing the Board Test System software. I have Quartus Prime PRO Edition 17.1.240 software. Even the Board Test System software indicates tha...
- 3 years ago
Hi there,
You JTAG chain seems wrong, you just need auto detect, The 10M。。。is max 10, and you just can add sof in its flash~ You don't need to add device by yourself~
Finees
3 years agoHi WZ2
Thank you for information, however the problem is the same.
From everything that I am seeing, it looks like the board is configured for a development package that is based on Quartus-Ver16.1.1.200 but, the only available development package is based on 17.1.0.240.
Now if I try reprogram the System MAX10, with dev -archive .pof, I would have the version 17 system from development package on the board and it would be compatible. So, when I try to program this MAX10with my USB-Blaster (JTAG port) I get error code 35.
Do you have any recommendation?
