What is significance of the HSIODR minimum data rate?
1. The low speed I/O banks have lower maximum frequency than other I/O banks
because of longer propagation delays. However, the delays do not affect the timing
parameters such as slew rate, rise time, and fall time.
2. True PPDS have better timing performance due to that the p and n are delayed equally. Emulated PPDS are GPIO that are created to invert each other, and external termination resistor is required. For the termination scheme, See: https://www.intel.com/content/www/us/en/programmable/documentation/sam1394433606063.html#sam1394436219455
3. Mode here means how many data lanes. x4 means 4 data lanes to 1 clock, x8 means 8 data lanes to 1 clock and so on
4. Each mode have a different range of data rate. Example x1 have min 10 and max 100...meaning you if you have 1 data lane implementation, you have the choice to transfer between 10~100Mbps. But if you have x10, your min and max is 1, meaning you have no choice but to each lane transfer at 10Mbps (to have an aggregated 100Mbps for all 10 lanes)
- JonWay_altera6 years ago
Correction typo: But if you have x10, your min and max is 10
