What is rx_pma_iqtxrx_clkout signal ?
Hello Dlim,
I have gone through "ug_arria10_xcvr_phy.pdf"
The reset sequence suggested by you is important from reception/transmission of data.
My test scenario is about clock generation, that too specifically about CDR block.
I want to understand why CDR block generates 31.38 Mhz clock if no input is present on Rx lane and rx_set_lockedtodata is high ?
This is important because in my design I will be using RX pma clock as a reference clock to a fPLL instance.
For better understanding if you could share below things it would be helpful.
1) Block diagram listing out analog block and digital blocks.
2) Various reset signals controlling analog block and digital block.
3) AC-DC Characteristics of each analog block.
4) Input-Output specification of each digital block.
Thanks & Regards,
Sachin Jadhav
