What is rx_pma_iqtxrx_clkout signal ?
- SJadh17 years ago
Hello dlim,
Thank you for responding.
I am cascading output clock(rx_pma_clkout) of RX PMA to the reference clock of fPLL instance so as to generate transmit clock.
I have configured RX PMA CDR to use local on-board reference clock as source. Local reference clock frequency is 108Mhz.
Transceiver is configured with Data rate is set to 1.62G and Data width is 32bit in PCS direct mode.
I am manually controlling RX CDR.
Below is my observation.
1) When rx_set_locktodata, rx_set_locktoref is 2'b00, I see a very jittery clock on rx_pma_clkout.
2) When rx_set_locktodata, rx_set_locktoref is 2'b01, I see a very clean 50.625 Mhz clock
3) When rx_set_locktodata, rx_set_locktoref is 2'b1X, I see a very clean of 31.38Mhz (What is the source of this clock)
In my test setup as of now I don't have any high speed data reception on serdes.
Why CDR is outputing 31.38 Mhz when rx_set_locktodata, rx_set_locktoref is 2'b1X ?
I also don't see my fPLL instance getting locked, when I set CDR to rx_set_locktodata, rx_set_locktoref is 2'b01.
Do I need to calibrate PLL for getting locked whenever there is change in rx_set_locktodata and rx_set_locktoref combination ?
Thanks & Regards,
Sachin Jadhav
