15 years agoWhat is PCML?
Hi, I am confused about the PCML, I think it is a I/O standard like CML(Current Mode Logic), and so I guess PCML means Pseudo Current Mode Logic. But the Glossary in Altera's web sit defi...
15 years ago --- Quote Start --- Hi hdjun, Take a look at this thread: Since the transceiver circuits on FPGAs are designed to interface to many standards, PCML (pseudo current-mode logic) is whatever Altera wants it to mean, and they don't really document it well :) The thread above has a simplified model of the transmitter (its not the circuit in the first attachment in the thread, look further down). Cheers, Dave --- Quote End --- Hi, Dave Your reply and your post message did a really great help to me! Thank you very much! Now, throught my simulation on SPICE, I think the equivalent curcuit of PCML transimiter output buffer is not similar to PCML. In fact, when using the terminition, no matter internal or external one, the transimitter output's behavior is more like the output structure of LVDS, which means when the positive pin drive +8mA current while the negetive pin drive -8mA current at the same time. In this equivalent curcuit, the results of Voh and Vol can match with your experiment data. But I don't know How is equilent curcuit can be implemented in Arria II GX output buffer. In LVDS's structure, there is four bipolar or cmos swithers to change the direction of output current, among the four swithers, there are two of them are near the termination voltage soure. While in PCML, altera says is the internal termination is off, the output of transmitter is tristate with open drain, where are the two swithers near the termination voltage source?? Further more, I want to use the ArriaII GX transimtter as an output to drive the input of one programmable delay chip NB6L295. The input of NB6L295 can be compatible with the 1.5-V CML standard. If the equivalent curcuit we got is correct, the Voh, Vol, and Vcom can meet the demands of NB6L295 and 1.5-V CML standard. But I wonder what is the maxium sink current the transimitter internal termination resisters can bear, for the 1.5-V termination at the the receiver will give a maxium current of about 12mA through the transimitter's termination resistor when the termination voltage is 0.65V at the transimitter neerend. thank you for help again!!
