15 years agoWhat is micro Setup time?
Can anyone please explain what "micro setup time [uTsu]" means. Thanks, AA
14 years agoFPGA is similar to clock distribution as a PCB therefore you have the same issues. Most people will try to keep the clock skew down by using a global clock. Fast routes and local/global clocks are used on data that needs low skew as well across a broad spectrum of the part. One can use enables and pipelining to improve timing.
