15 years agoWhat is micro Setup time?
Can anyone please explain what "micro setup time [uTsu]" means. Thanks, AA
14 years agoIt important to track the data path clock propagation as well as the clock to out times of the part. The propagation time of the clock to part input helps the setup, whereas propagation time of data path hurts the setup time. This of course assumes that you aren't dealing with a bidirectional data bus. In that case skew on clock will help setup on one end and hurt it on the other end.:D
Not bad for a female ehh? I can even tell you how to measure setup and hold, though you should already know this from college if they still teach such basics anymore.
