GS3345
2 years agoWhat is Cyclone 10 LP Configuration and programming method?
Please check if the Cyclone 10 LP Configuration connection is correct. I connected Cyclone 10 LP (10CL006YE144C8G) and EPCQ4ASI8N as shown in the circuit below. MSEL[2..0]=010 was set (based on 2.5V...
WZ2
2 years agoBesides addressing the issue with VCC_PLL, I also recommend pull down the TCK. Additionally, your USB Blaster II seems somewhat different from the one we commonly use. You can refer to the following link to confirm if the connection is correct: https://cdrdv2-public.intel.com/666496/ug-intel-fpga-download-cable-ii-683719-666496.pdf. Furthermore, if you provide me with the error messages from Quartus, it might offer more clues.
