GS3345
2 years agoWhat is Cyclone 10 LP Configuration and programming method?
Please check if the Cyclone 10 LP Configuration connection is correct. I connected Cyclone 10 LP (10CL006YE144C8G) and EPCQ4ASI8N as shown in the circuit below. MSEL[2..0]=010 was set (based on 2.5V...
FvM
2 years agoHi,
there's at least one serious fault. VCCD_PLL has to be connected to 1.2V rail.
Everything else looks correct at first sight. AS memory can be programmed through JTAG indirect method, generate .jic file with programming file converter tool, open it in Quartus programmer and write it to flash.
As first test for FPGA function, either try to write .sof file or perform FPGA autodetect in Quartus programmer.
