CRAMF1
6 years agoWhat IO standard(s) require settings involving "Half VCCIO" and "Half Signal Swing"
I have compiled an example design from Intel in QPP 18.1 and I am getting errors with the following settings: set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -rise set_glob...
CRAMF1
6 years agohttps://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2019/global-setting-is-not-supported-the-instance-as-listed-below-in-.html?wapkw=329006
You will not see this within the forum. You have to do a search for "329006" here:
Somebody has said that these assignments are obsolete. Why does Intel still keep them and cause confusion?
Chundra
