14 years ago
What I need to start with Ethernet Project ?
Simple Project Description:
PC (using Labview) communicate with Altera Nios II Embedded Evaluation Kit over ethernet port. PC send command and FPGA response (echo application or flash LED).
What I need to understand From FPGA Side ?
From my knowledge I need to understand:
* NIOS II
* TSE IP Core
* NicheStack TCP/IP Stack
Is that really what I need to understand? and what else I need?
    The Nios II / TSE / uCos / Interniche is the easiest way to get an Ethernet interface running on an Altera FPGA, as it's the only solution officially supported by Altera. If you have a development kit you should have an example design that's ready to run.
    Going without the Nios CPU and the Altera drivers is possible but more complicated.
    Simple Sockets Server is a good example to start, but it has uCOS and I think uCOS is early for me to start with it without understanding principle of ethernet with fpga in deep.
    I hope so if there is any example used only TSE IP Core without NIOS.
    You will also probably need to learn a few things about the uCOS operating system as it is the one used by default in the Altera Nios II EDS. In the software examples you have a Simple Sockets Server code that you can use as a starting point.
