16 years agoWhat does an address space contain?
Hi, I added a simple component LCD12864 into nios system.Then I got the address space from system.h:#define LCD12864_BASE 0x00000800#define LCD12864_SPAN 16But I don't know:1) Why SPAN=16.2) What co...
16 years agoThe answer is in these two pieces of code:
else if (avs_chipselect & avs_write)
begin
case (avs_address)
0: coe_e <= avs_writedata;
1: coe_rw <= avs_writedata;
2: coe_rs <= avs_writedata;
3: coe_data_o <= avs_writedata;
endcase
endand if (avs_chipselect & avs_read)
begin
if (avs_address == 3)
readdata_r <= coe_data_i;
else
readdata_r <= 8'b0;
end
else
readdata_r <= 8'b0;
assign avs_readdata = {24'b0, readdata_r}; Writing on the first 3 addresses changes one signal to the lcd controller, controlled by the LSB of your data word (i.e. write "0" to drive the signal low and "1" to drive it high). Address LCD12864_BASE controls E, LCD12864_BASE+4 controls RW, and LCD12864_BASE +8 controls RS. On the last address (LCD12864_BASE+12), you control the data written to the controller with the low 8 bits. Reading on the first 3 addresses returns 0, and reading from LCD12864_BASE+12 returns you the word written by the LCD controller in the low 8 bits. The component uses 32-bit data registers for read and write, and has 4 registers. That's why the span is 4*4=16. This is also why you need to increase the address in steps of 4 to access each register.
