16 years agoWhat are the differences between Altera & Xilinx Deserialization?
What are the differences between Altera & Xilinx Deserialization? anybody knows? Xilinx released several application notes, e.g." Connecting Xilinx FPGAs to Texas Instruments ADS527x Series AD...
16 years agoOnly one clock is necessary, as PLL does the rest. Technically you should be able to do everythign with the altlvds block. I don't know enough about the bit swap mux, but would be surprised if it were necessary. The data should come out in parallel to your data clock rate. If the order is incorrect, you just switch the hookup. I'm not sure what they're changing on the fly.
