12 years agoWeird sticky bit in SPI data
I'm using the Altera SPI Verlog code as a basis for an SPI / SD card interface for a Z80 based computer using a MAX3000A as the CPLD. When I clock the SPI bus at a low data rate (around 430Khz ...
12 years ago --- Quote Start --- Where did the code come from? Did you write it? It looks very much like code for a test bench to me and not something intended for synthesis. The code contains a relatively large number of 'always @' statements. Between them the are implying a lot of signals that will be interpreted as clocks, something that'll cause Quartus a lot of trouble when trying to fit it to the small CPLD you're using. The following discusses always blocks and their intended use: verilog: always @ blocks (http://www-inst.eecs.berkeley.edu/~cs150/sp13/resources/always.pdf) I suggest you have a good look through it. I hope it helps. Regards, Alex --- Quote End --- Hi, thanks for the response. I thought I'd already responded to this thread, but I cant see my post. The code is an Altera sample. I've since re-written the code myself and its running much better, except for one thing -- the clock divider. I'm generating my SPI clock from a counter and using a bit index to perform a power of 2 divide for the clock. The clock generation looks like this --
reg rControl;
wire rClkDivide = rControl;
always @ (posedge iclkHost)
begin
rClockCounter <= rClockCounter + 1;
rSPIClk <= rClockCounter;
end
But I find when I use this, I get random errors occurring in the data with missed byte reads. But if I use a fixed clock like this -- always @ (posedge iclkHost)
begin
end
It works perfectly, and that's at a full 7.5Mhz. At any clock divider taken from the control register, I get errors. I'm really not sure why?? Any pointers on this much appreciated, as otherwise my SPI code is working really well. Thanks!
