12 years agoWeird sticky bit in SPI data
I'm using the Altera SPI Verlog code as a basis for an SPI / SD card interface for a Z80 based computer using a MAX3000A as the CPLD. When I clock the SPI bus at a low data rate (around 430Khz ...
12 years ago --- Quote Start --- Where did the code come from? Did you write it? It looks very much like code for a test bench to me and not something intended for synthesis. The code contains a relatively large number of 'always @' statements. Between them the are implying a lot of signals that will be interpreted as clocks, something that'll cause Quartus a lot of trouble when trying to fit it to the small CPLD you're using. The following discusses always blocks and their intended use: verilog: always @ blocks (http://www-inst.eecs.berkeley.edu/~cs150/sp13/resources/always.pdf) I suggest you have a good look through it. I hope it helps. Regards, Alex --- Quote End --- This is Altera sample code from here (search for SPI Master) -- http://www.altera.co.uk/support/examples/max/exm-max.html Thanks for the feedback, I think I'll rewrite it myself now I understand better how SPI works. I must admit, it's not how I would have written it, but then I'm new to hardware design, so I usually think its my lack of experience as to why I don't understand the approach.
