12 years agoWeird sticky bit in SPI data
I'm using the Altera SPI Verlog code as a basis for an SPI / SD card interface for a Z80 based computer using a MAX3000A as the CPLD. When I clock the SPI bus at a low data rate (around 430Khz ...
12 years agoWhere did the code come from? Did you write it?
It looks very much like code for a test bench to me and not something intended for synthesis. The code contains a relatively large number of 'always @' statements. Between them the are implying a lot of signals that will be interpreted as clocks, something that'll cause Quartus a lot of trouble when trying to fit it to the small CPLD you're using. The following discusses always blocks and their intended use: verilog: always @ blocks (http://www-inst.eecs.berkeley.edu/~cs150/sp13/resources/always.pdf) I suggest you have a good look through it. I hope it helps. Regards, Alex
