NMinh3
7 years agoWe would like to request for FA
Part Number AE1818-7675LF Model AEE8251-60666LF Affected SN 1. E82516066623182500057 2. E82516066623183200088 3. E82516066623184500101 4. E82516066623183800035 5. E8...
Zawani_M_Intel
7 years agoThank you for contacting Intel Community.
Please be noted that Intel FPGA requires details information for failure analysis request. Please help to answer questions below in order for us to better understand your position.
1. Please provide full device details.
1.1. Device name:
1.2. Full part number:
2. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
3. What is the failure symptom? Please elaborate the failure symptom in detail.
4. When did the failure happen? How did you discover the failure?
5. How did you determine the failure? Please elaborate the procedures.
6. Does the failure unit ever working before failure?
7. Did they violate solder re-flow temperature profiles, moisture sensitivity?
8. Did you swap the failure device to a known good board? Is the failure following the device or board?
Wani
NMinh3
7 years agoHi Wani,
Any update on below request?
Pls help to respond this ASAP as we need the disposition on this FA request urgently.
Thank you.
Nabilah
