NMinh3
7 years agoWe would like to request for FA
Part Number AE1818-7675LF Model AEE8251-60666LF Affected SN 1. E82516066623182500057 2. E82516066623183200088 3. E82516066623184500101 4. E82516066623183800035 5. E8...
Zawani_M_Intel
7 years agoThank you for contacting Intel Community.
Please be noted that Intel FPGA requires details information for failure analysis request. Please help to answer questions below in order for us to better understand your position.
1. Please provide full device details.
1.1. Device name:
1.2. Full part number:
2. What is the failure rate? What is the failure rate vs. tested sample? Example: 2 out of 100 units.
3. What is the failure symptom? Please elaborate the failure symptom in detail.
4. When did the failure happen? How did you discover the failure?
5. How did you determine the failure? Please elaborate the procedures.
6. Does the failure unit ever working before failure?
7. Did they violate solder re-flow temperature profiles, moisture sensitivity?
8. Did you swap the failure device to a known good board? Is the failure following the device or board?
Wani
NMinh3
7 years agoHi,
Refer below:
1.1. Device name: IC 1.695M-bit EEPROM CMOS 20-PLCC
1.2. Full part number: AE1818-7675LF
- 7 / 246
- Test program aborted due to E8251-60666 failed at Store Module Eeprom.
[cid:[email protected]][cid:[email protected]]
- The failure happen while perform Download Firmware.
- The test program shown E8251-60666 “Eeprom header read from UUT does NOT match header written to UUT.
- Refer to the schematic, U101 is the configuration Eeprom.
- We have perform measurement VOLTAGE for U101, good vs bad.
U101 Measurement Voltage (V)
No
U101
GOOD
BAD
1
Pin 1
3.35v
3.30v
2
Pin 2
3.38v
3.30v
3
Pin 3
0
0
4
Pin 4
0
0
5
Pin 5
3.26v
3.30v
6
Pin 6
0
0
7
Pin 7
0
0
8
Pin 8
3.30v
0.035v
9
Pin 9
3.30v
0.035v
10
Pin 10
0
0
11
Pin 11
2.8v
2.79v
12
Pin 12
3.26v
3.30v
13
Pin 13
3.30v
3.30v
14
Pin 14
3.30v
3.30v
15
Pin 15
0
0
16
Pin 16
0
0
17
Pin 17
0
0
18
Pin 18
3.30v
3.30v
19
Pin 19
3.30v
3.30v
20
Pin 20
3.30v
3.30v
No
No
We have done swapping experiment, the failure is following device.
Thank you.
Nabilah
