12 years agoWaveform simulation
Hi all.
I have tried this coding and it successful. I want to generate the waveform. But, it does not produce waveform at output port. Could someone tell me why it happens. Thanks in advance library ieee; use ieee.std_logic_1164.all; entity pulse is port( clk_in : in std_logic; --clk_out : out std_logic; data_in : in std_logic; reset : in std_logic; data_out : out std_logic_vector(15 downto 0)); end pulse; architecture fifi of pulse is -- Build an enumerated type for the state machine type state_type is (s0, s1, s2, s3, s4, s5, s6, s7, s8, s9, s10, s11, s12, s13, s14, s15 ); -- Register to hold the current state signal state : state_type; --clock divider signal temporal : std_logic; signal counter : integer range 0 to 757 := 0;---clock divider utk f=33kHz begin frequency_divider: process (reset, clk_in) begin if (reset = '1') then temporal <= '0'; counter <= 0; elsif rising_edge(clk_in) then if (counter = 757) then temporal <= NOT(temporal); counter <= 0; else counter <= counter + 1; end if; end if; end process; --clk_out <= temporal; --begin -- Logic to advance to the next state process (temporal, reset) begin if reset = '1' then state <= s0; elsif (rising_edge(temporal)) then case state is when s0=> if data_in = '1' then state <= s1; else state <= s0; end if; when s1=> if data_in = '1' then state <= s2; else state <= s1; end if; when s2=> if data_in = '1' then state <= s3; else state <= s2; end if; when s3 => if data_in = '1' then state <= s4; else state <= s3; end if; when s4 => if data_in = '1' then state <= s5; else state <= s4; end if; when s5 => if data_in = '1' then state <= s6; else state <= s5; end if; when s6 => if data_in = '1' then state <= s7; else state <= s6; end if; when s7 => if data_in = '1' then state <= s8; else state <= s7; end if; when s8 => if data_in = '1' then state <= s9; else state <= s8; end if; when s9 => if data_in = '1' then state <= s10; else state <= s9; end if; when s10 => if data_in = '1' then state <= s11; else state <= s10; end if; when s11 => if data_in = '1' then state <= s12; else state <= s11; end if; when s12 => if data_in = '1' then state <= s13; else state <= s12; end if; when s13 => if data_in = '1' then state <= s14; else state <= s13; end if; when s14 => if data_in = '1' then state <= s15; else state <= s14; end if; when s15 => if data_in = '1' then state <= s0; else state <= s15; end if; end case; end if; end process; -- Output depends solely on the current state process (state) begin case state is when s0 => data_out <= "0000000000000001"; when s1 => data_out <= "0000000000000010"; when s2 => data_out <= "0000000000000100"; when s3 => data_out <= "0000000000001000"; when s4 => data_out <= "0000000000010000"; when s5 => data_out <= "0000000000100000"; when s6 => data_out <= "0000000001000000"; when s7 => data_out <= "0000000010000000"; when s8 => data_out <= "0000000100000000"; when s9 => data_out <= "0000001000000000"; when s10 => data_out <= "0000010000000000"; when s11 => data_out <= "0000100000000000"; when s12 => data_out <= "0001000000000000"; when s13 => data_out <= "0010000000000000"; when s14 => data_out <= "0100000000000000"; when s15 => data_out <= "1000000000000000"; end case; end process; end fifi;1 Reply
you havent included "temporal" or counter on the waveform. temporal changes every 757 clocks, which is not shown on the waveform.
But it is bad practice to use a counter to generate a clock. Much better to generate a clock enable and clock the whole system at the source clock frequency.
