Watchdog Disable new SOC EDS Flow
- 3 years ago
Hi Robert,
You can disable the watchdog from uboot using the new flow, the details in the github
https://github.com/altera-opensource/u-boot-socfpga
follow the build u-boot step in building bootloader
- Watchdog:
CFG_SYS_WATCHDOG_FREQ
Some platforms automatically call WATCHDOG_RESET()
from the timer interrupt handler every
CFG_SYS_WATCHDOG_FREQ interrupts. If not set by the
board configuration file, a default of CONFIG_SYS_HZ/2
(i.e. 500) is used. Setting CFG_SYS_WATCHDOG_FREQ
to 0 disables calling WATCHDOG_RESET() from the timer
interrupt.
You can use this step to disable the watchdog
Thank you,
Aliff
Hi Robert,
Anymore help you needed base on the solution given?
Thank you,
Aliff
Hi Aliff,
We decided to write to the CPU Watchdog reset registers in uboot to solve our issue, compiling with the CFG_SYS_WATCHDOG_FREQ set to 0 did not work as expected.
We can close this thread. Thank you for the assistance.
-Robert
