18 years agoWas my chip burnt ?
I tested the voltage of ASM1117 1.2V on my board, which is 2.5V, and the current is 190.2mA. Obviously, the VCCINT of cyclone2 should be 1.2v, so i doubt whether the chip was burnt. When i cut t...
18 years agoA quick check if the chip is ok or not is provided by the Auto-detect in the programmer options. If you are programming the board you can use this feature to ascertain if the chip is defective.
regards, Kumar Vijay Mishra.
