18 years agoWas my chip burnt ?
I tested the voltage of ASM1117 1.2V on my board, which is 2.5V, and the current is 190.2mA. Obviously, the VCCINT of cyclone2 should be 1.2v, so i doubt whether the chip was burnt. When i cut t...
18 years agoDid you use a cleaning solvent after your soldering re-work?
The resistance values are really fuzzy, sometimes it happens if the soldering flux is mucking up the tracks.
