10 years agoWarning: RST port on the PLL is not properly connected
Hello! I'm using PLL in my project for the Cyclone V device. And i have this warning in Quartus (Quartus Prime 16.0): --- Quote Start --- Warning: RST port on the PLL is not properly con...
10 years ago --- Quote Start --- Hi coder, I recommend looking at Alex's suggestion in this thread, it helped me. http://www.alteraforum.com/forum/showthread.php?t=50680&p=208790#post208790 Basically drive the PLL reset based on the locked output. The recommendation to use a counter is a good idea. --- Quote End --- Thanks for the advice. The idea of Alex's suggestion is clear. It seems me strange that i turn on PLL Auto Reset (that automatically self-resets the PLL on loss of lock), PLL reconfiguration and clock switchover is not enabled in the design and i still have a warning: "The reset port on the PLL should be connected. If the PLL loses lock for any reason, you might need to manually reset the PLL in order to re-establish lock to the reference clock."
