Warning message: "Missing drive strength"
- 7 years ago
Quartus is weird: it says you are "missing drive strength" because you didn't explicitly create the assignment yourself to have it written into the .qsf file. What you see is the default and is not written in the .qsf. You can safely ignore this or manually add a drive strength assignment.
Hi Daniel,
Kindly refer to previous thread with similar issue.
https://forums.intel.com/s/question/0D50P00003yyL9mSAE/why-warning-missing-drive-strength-
I hope this could help you.
Thank you.
- MLars191 year ago
Hi
This issue arises when using the ASMI IP, I get these warnings:
; I/O Assignment Warnings ;
; Pin Name ; Reason ;
; sd2~ALTERA_DCLK ; Missing drive strength ;
; sd2~ALTERA_SCE ; Missing drive strength ;
; sd2~ALTERA_SDO ; Missing drive strength ;
+-----------------+------------------------+It is not possible to set drive strength in these pins as far as I know
Is there any way to constrain these to get rid of the warning.
There is always the possibility to supress these warnings but I would prefer to take care of them so it doesn't become warnings
/Magnus
