Norick
7 years agoWarning message: "Missing drive strength"
Hello with Quartus 18.0 and a Max10 device I get following I/O assignment warning message: When I check the Pin Planner I see following default values: Question: Why this warning mes...
- 7 years ago
Quartus is weird: it says you are "missing drive strength" because you didn't explicitly create the assignment yourself to have it written into the .qsf file. What you see is the default and is not written in the .qsf. You can safely ignore this or manually add a drive strength assignment.
sstrell
7 years agoQuartus is weird: it says you are "missing drive strength" because you didn't explicitly create the assignment yourself to have it written into the .qsf file. What you see is the default and is not written in the .qsf. You can safely ignore this or manually add a drive strength assignment.
