15 years agoWarning: Ignored filter: *ws_dgrp|dffpipe_5e9:dffpipe9|dffe10a (RapidIO)
Warning: Ignored filter: *ws_dgrp|dffpipe_5e9:dffpipe9|dffe10a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Warning: Ignored set_false_path: Argume...
15 years agoTimequest gives the warnings below. He can't find the dcfifo_vof1 file, because it's not there, the SOPC builder didn't make it nor did I. Do I even need it? The RapidIO MegaCore Function v10.0 User Guide doesn't state anything about a DCFIFO.
Ignored assignments for entity "dcfifo_vof1" -- entity does not exist in design
Warning: Assignment for entity set_instance_assignment -name CUT ON -from delayed_wrptr_g -to rs_dgwp|dffpipe6|dffe7a -entity dcfifo_vof1 -tag quartusii was ignored
Warning: Assignment for entity set_instance_assignment -name CUT ON -from rdptr_g -to ws_dgrp|dffpipe9|dffe10a -entity dcfifo_vof1 -tag quartusii was ignored
Warning: Ignored filter at qsta_default_script.tcl(862): *ws_dgrp|dffpipe_5e9:dffpipe9|dffe10a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Warning: Ignored set_false_path at qsta_default_script.tcl(862): Argument <to> is not an object ID
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *rs_dgwp|dffpipe_4e9:dffpipe6|dffe7a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *ws_dgrp|dffpipe_qd9:dffpipe9|dffe10a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *rs_dgwp|dffpipe_pd9:dffpipe6|dffe7a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *ws_dgrp|dffpipe_kd9:dffpipe10|dffe11a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *rs_dgwp|dffpipe_jd9:dffpipe6|dffe7a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *ws_dgrp|dffpipe_sd9:dffpipe9|dffe10a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
Warning: Ignored filter at qsta_default_script.tcl(862): *rs_dgwp|dffpipe_rd9:dffpipe6|dffe7a* could not be matched with a clock or keeper or register or port or pin or cell or partition
Info: read_sdc
