10 years agoWarning (10236): Verilog HDL Implicit Net warning at cc_r2a_refdes_sdhc_cntrl.v(40):
before i begin let me explain that in the last post i made i had a problem deciding whether to assign a sdram pin known as SDRAM_CKE ... in the tutorial i am using in the top level entity file it is ...
10 years agoHave you got an input or output declared on your top level module Verilog file with the name SDRAM_CKE?
