16 years agowaiting for clock ?!
Hello, I am using signal-tap to investigate a problem. But currently the problem is signalTap itself. I have a trigger clock (100 Mhz), which I am sure its running, otherwise nothing would run...
16 years ago --- Quote Start --- no they're displayed in black and I dont see any warning. this is a really strange behaviour. I have used S.T. really often in the past, but this is also new for me --- Quote End --- Hi, I only run into this problem when the selected node was removed or renamed by Quartus, but then the node was dispalyed in red colour. Did you change the Quartus version ? Kind regards GPK
