16 years agowaiting for clock ?!
Hello, I am using signal-tap to investigate a problem. But currently the problem is signalTap itself. I have a trigger clock (100 Mhz), which I am sure its running, otherwise nothing would run...
16 years ago --- Quote Start --- Hi, did you get any warning during compilation that your clock node isn't found ? When you open the stp-file is the clock node dispalyed in red colour ? Kind regards GPK --- Quote End --- no they're displayed in black and I dont see any warning. this is a really strange behaviour. I have used S.T. really often in the past, but this is also new for me
