17 years ago
wait statement inside process
Hi all,
I faced some problem when I trying to compile my following code. The error replied was only one wait statement is allowed in the process. I have tried putting IF statement but it took 10,000 iterations. May I know how can i change my code?
Main : process
variable counter : counter_type := 0;
begin
-- HWY green, SRD red
wait on (CLOCK until CLOCK = '1' and SRDcar = '1');
if (HWYcar = '1') then
Counter := 0;
loop
wait until CLOCK = '1';
exit when (HWYcar = '0' or Counter = long_cycle);
Counter := Counter + 1;
end loop;
end if ;
Thank you so much
    You can replace "if rising_edge(CLOCK) then" with "if CLOCK'event and CLOCK = '1' then" or you open the std_logic_1164 library and check that the rising_edge function is in there.
    yup... i included that...
    library ieee;
    use ieee.std_logic_1164.all;
    was trying to figure this out for the past 2 days...
    Have you included the std_logic_1164 library because that is where the rising_edge function is declared.
    thank you ben. but the error return now is rising_edge is used but not declared. sorry for bothering. I'm very very new this software.
    Main : process
    begin
    if SRDcar = '1' then
    if HWYcar = '1' then
    counter := 0;
    elsif counter = long_cycle then
    null;
    else
    counter := counter + 1;
    end if;
    end if;
    end if;
    end process;
    I think this should be something like what you want.
    Ben
