14 years agowait statement error
hello,
here i'm getting error in using of wait statement. how to use wait statement for executing an event after a particular time like after every 83 ns high and low respectively?3 Replies
thank you for your advice, yes i want to divide the clk frequency by 3 to get 666kHz which is equal to 166ns....
First you should use the numeric_std library, to have access to the signed and unsigned types.
Then declare count and z as unsigned(1 downto 0) and unsigned(6 downto 0) respectively, and you can directly use arithmetic operators on them:
I don't understand the values you use though... do you want to divide the clock frequency by 3 (meaning 666.666kHz) or by 3000 to get 666 Hz? IF dividing by 3 you won't be able to produce a square signal with 50% duty cycle. But you can generate a clock enable signal quite easily.count<=count+1; IF ((Z = 15) or (Z = 30) or (Z = 45) or (Z = 60)) then clkout<= not clkout; END IF; IF(Z = 83) THEN Z <="0000000"; ELSE Z <=Z+1; END IF; - Altera_Forum
please post your code.
wait statements with specific delays are not appropriate for synthesis, only simulation. For synthesis you need to use counters to wait for the specified time.
