16 years agoVoltage Regulators for Cyclone III
Hi. I want to use a LM317 regulator to feed my EP3C16Q240C8. The problem is that the minimum voltage the regulator is able to output is 1.25 V while the core voltage for the FPGA is 1.2 V. Is this s...
16 years agoThis might work, but I would strongly urge against it, especially since you are talking about the core voltage. There is practically no margin left on the high-end of the rail. Even if regulation is perfect, the part will run warm.
Perhaps I'm a bit more conservative due to the line of work I'm in, but I try to aim for the center of the spec if possible. It's also kind of silly, since you can get 1.2V fixed linear regulators for about $1-2 capable of sourcing several amps of current. (http://search.digikey.com/scripts/dksearch/dksus.dll?detail&name=fan1112sxct-nd)
