9 years agoVoltage level issue on MAX10
Hello, i'm trying to test my MAX10 using clock of 1MHz on some pins. one of the HW pins is not output the signal as expected, the clock goes high to 3.3v and then down to 1.6v instead of 0v. t...
9 years agoI have a similar issue.. I am creating a 150MHz clock from the internal PLL using using a 25MHz external clock.
I changed the clock assignment to 100Mhz and the output looks great. I am using 10M02SCE144C8G My 25MHZ clock is applied to pin 27 My 150MHZ clock comes out on pin 141, I have a TP at pin 31, where I send a copy of the signal. On pin 141 I have a series termination resistor. which I have lifted one side... Not understanding why the frequency is ok but voltage levels are off.. my PLL outputs are: C0 100MHZ internal C1 100MHz external C2 150MHz external C3 FPGA_PIN31 Any help would be great..
