10 years agoVoltage GPIO DE1/DE2?
Hello! I have a question, everybody help me. How much is the voltage input/output GPIO DE1/DE2? And if i assign high signal (5v), low (0v) from power supply to GPIO, Kit DE1/DE2 have get signal with ...
10 years ago --- Quote Start --- The DB9 serial port on some of the DE series boards are connected to a driver chip that can handle 5 volts easily. Alex was referring to the pins on the FPGA itself. You can easily damage an FPGA with too high a voltage. --- Quote End --- Thanks you! 1. But UART were designed by me. it just recieve singal from GPIO, i can assign signal RX to DB9 serial on DE? 2. If on wire RX signal use schematic 5v -> 3.3v and provide to GPIO, it true? it look like image. http://www.alteraforum.com/forum/attachment.php?attachmentid=11527&stc=1
