10 years agoVoltage GPIO DE1/DE2?
Hello! I have a question, everybody help me. How much is the voltage input/output GPIO DE1/DE2? And if i assign high signal (5v), low (0v) from power supply to GPIO, Kit DE1/DE2 have get signal with ...
10 years agoThe voltage of GPIO will depend on the IO standard that you set to it. You can double check the expected voltage levels from datasheet of the device.
