Steve-Mowbray-ENL
2 years agoVirtual Pin Assignments -- does Value=Off/On imply logic 0/1 for pin?
Probably dumb question but does setting a virtual pin value to ON imply that it will be at logic 1 state in the compiled design during user mode? For instance vpin1=1'b1 and vpin2=1'b0 resulting from...
TingJiangT_Intel
Contributor
2 years agoHi there, may I know why you need to know the initial value of the virtual pins. Do you need to do simulation?
Virtual pin usually used to do some optimization in timing and resources usage, so normally it won't be the final version of your design.
Steve-Mowbray-ENL
2 years agotop level file is reused between multiple projects on different target hardware -- we can reuse the top level file with virtual pins on lesser hardware so long as the state of the virtual pin is fixed known in the lesser hardware project -- improved hardware will have the pin as physical and the state will come from external source
