VIP Suite Design Example
As I understand it, you seems to have some inquires related to a ref design from the Intel web. Sorry as I do not have much insight into this design. To ensure we are on the same page, just would like to check with you on the following:
1. As I tried to download the documentation, I encounter webpage error. It seems like the documentation was located in the alterawiki which is no longer available. Just to check from where did you manage to download the user guide?
2. The design seems to be located in Design Store. However, seems like the link is not working as well when I clicked on it. Probably due to temporary server issue. I will try again tomorrow to see if it works.
3. Just to check with you if you run the design by default, are you able to run the design per the user guide?
4. Just to set a correct expectation that the design is generally provided "as-is" without Factory support. However, I will try my best to advise to my best knowledge.
5. Just to check with you if you have managed to simulate your customize design prior to hardware testing?
Chee Pin
