Video designed with openLDI_TX degraded after power cycle
Hi Mingyuexin,
Thank you for reaching out.
Apologize for the delayed response as we encounter some technical difficulty.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
I shall come back to you with findings.
Thank you for your patience.
ZH_Intel
Thank you very much for the response.
I found that resetting CVO and OpenLDI would remove the issue.
So I'm afraid there is timing issue between OpenLDI and the receiver chip on the board.
OpenLDI utilize altlvds_tx to convert parallel data to serial data. Since it's a hardcore ip (SERDES), so I did not set any output timing constraint for the pins. So if timing constraint on the output pins are necessary, how to set then? There is no timing data from the datasheet of the receiver chip on the board either.
Thank you very much for your time!
With best wishes
Mingyuexin
