16 years ago
[VHDL] Using the same register on many processes
Hi.
If i have a code like:
signal counter: integer etc;
PROCESS (clock25)
BEGIN
if (clock25 = '1') then
   counter <= counter +1;
end if;
END process;
PROCESS (clock25, ...)
BEGIN
   if (counter = etc) then
END PROCESS;
Can be a timing violation if the second process is executed because clock25 is rising up?
    The question isn't clear. The second process is combinational, as far shown. A timing violation can only occur in an edge triggered process.
    --- Quote Start ---
    --- Quote End ---
    I've this code:
        signal vsync_count : integer range 0 to 799;
        signal hsync_count : integer range 0 to 520;
        signal clock25 : std_logic;
        PROCESS (clock25)
        BEGIN
            IF (clock25 = '1') THEN
                hsync_count <= hsync_count+1;
                if (hsync_count < 96) then
                    hsync <= '1';
                else
                    hsync <= '0';
                end if;
            END IF;
        END PROCESS;
        PROCESS (clock25)
        begin
                if (hsync_count >= 144 )
                and (hsync_count < 784 )
                and (vsync_count >= 39 )
                and (vsync_count < 519 )
                then
                    rgboe <= '0';
                else
                    rgboe <= '1';
                end if;
            end if;
        end process;
    Are you sure that the 2nd process can't do a timing violation with hsync_count register?
    It's a safe design this?
    Thank you
    Depends on what you regard as safe. Generally, the combinational output of process 2 can be expected to have glitches, because it's not registered. In this special case, rgboe is permanently '1' because hsync_count never reaches 144 and the first condition is always false.
    Please also consider, that the sensitivity list of process 2 has no actual effect in synthesis, although Quartus II complains if it's missing.
    --- Quote Start ---
    --- Quote End ---
    Uhm, i want the output registered!
    With this code:
        PROCESS (clock25)
        begin
            if (clock25'event and clock25 = '1') then
                then
                    rgboe <= '0';
                else
                    rgboe <= '1';
                end if;
            end if;
        end process;
    the combinational output is registered right?
    When this process is executed, there is a reading in hsync_count register.
    But the first process is writing a new value inside this register.
    So, can be a timing violation or Quartus avoid this situation?
    Thank you
    The result from changed hsync_count value arrives at the rgboe register input after the clock edge. That's how simple synchronous FPGA logic with a common clock domain works. The Quartus timing analysis still has to check for two possible problems:
    - delay differences in the clock network
    - the logic delay between hsync_count registers and rgboe registers must be shorter than a clock period minus hold time.
