18 years agoVHDL timing
Hi all, I am new to VHDL so I suppose that my question is pretty basic: Suppose I have a simple buffer with input, output and enable. The input is connected to the output if enable = '1'. When ...
18 years ago --- Quote Start --- Let's say that I am not simulating the design but burning it to an actual CPLD. Isn't there a race condition between the enable and input signals? --- Quote End --- That would depend on the characteristics of the PLD and the routing / logic delays for your particular layout. You could potentially get a glitch on the output - it depends what the on/off and propagation delays are for the buffer and which signal arrives first. You could always run a gate level simulation with timing delays to check this - but it could change for each compilation. If it's really an issue then you might want to think about your design in a bit more detail. --- Quote Start --- Can I always assume that the buffer's output will change immediately? --- Quote End --- The output will never change immediately on an actual chip - there will always be some delay there - you need to work out how much is OK for your design. Depending on what device you're using you could add timing constraints so that you don't end up with a glitch at the output. have a think about what the signals are actually doing when they get to the outside world and whether you have a problem or not before diving into constraints or changing your design.
